Fuel tank guard thingamy - is it needed?
(In Topic #183109)
I've had mine blasted and powder coated but its pretty nackered with quite a few small holes in it. Do I even need this? Does it serve any purpose?
The main purpose is to help dissapate the heat that emanates from the exhaust, which runs very close to the tank.
Originally they were not installed but problems with fuel vapourisation led to the recall and install of the shields. (I am sure I have a recall notice somewhere)
Incidentally I believe they were all manufactured in Mexico, I have never seen one stamped from Germany and I have a fair share of them, if you have had yours blasted you should be able to make out the stamp
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
tubbett said
That would really depend on what engine you are running. Hot running GTI, absolutely!
Incidentally I believe they were all manufactured in Mexico, I have never seen one stamped from Germany and I have a fair share of them, if you have had yours blasted you should be able to make out the stamp![]()
Great info there, I've had the same problem with vapourisation and leads to pinking when it's been sat idling stationery for a while, quite close to my Jetex, been after a decent one for a while if anyone has one
Was hoping I could do without it but I guess that would be too easy
I''ll have to keep my eyes peeled for a fresh one.
Thanks for the help
Most of the newer heat sheilds are alloy with a covering over them so they are easy to bend/mold into shape but you might need to make some kind of fixing.
I already had the tape in the garage so thought it was worth a try, i knew it'd be easy to form to the curves of the tank too. Here's a pic.
