Fuel pump
(In Topic #234103)
About 1/4 - 1/2 a turn. Will be quite tight so use some care and try to use as close fitting flat driver in the slots to avoid damage. Be careful when removing it from the tank and clear as much dirt as you can from round it before
In the past I've used the handles of some water pump pliers or tinsnips that were a tight fit in the slots and twist off.
Don't go walloping it, it will break bits off.
Remove it carefully as they are difficult to find if you break it.
Fuel pump
Thanks all for replys.
Not budging at all. Tried with flat head, but very worried will break. Seen there's tools you can get but again all look for different caps to mine.
Sent from my SM-G986B using Tapatalk
Regional Host NE
Re: Fuel pump
Sent from my SM-G960F using Tapatalk
