Fuel pump testing
(In Topic #202426)
I have 12v at the pump when you turn on the ignition. The pump doesn't whirr but it does feel like it clicks so I've removed it from the car and put 12v on it. It's doing something but I certainly doesn't sound like it's spinning! It sounds more like it's vibrating, like a diaphragm pump like you use in a fish tank!
Can anybody advise on the best way to test the pump? Should it sound like it's spinning?
Thanks.
Matt.
View topic: Fuel Tank cleaning *HowTo* clear that blockage - The Mk1 Golf Owners Club
Looking at the pictures in the link, there is a little filter in the pump, I don't believe my pump has that!
the pattern tanks are inferior design with just a metal cup spot welded to the bottom, and they just dont work for petrol cars. diesel cars its not so bad so they manage ok I believe.
these were originally sold as both gti and diesel, but sicne many have found they dont actually work in a gti i guess they were revised to only fit diesels
So the tanks advertised on vw heritage and classic-vw.co.uk will cause problems? These are both listed as being for diesel and GTI. There were some on eBay, although he's sold out now that we're listed only for the GTI. Item no 111658254207.
Thanks. Matt.
the post-84 cab/rocco solution was to move the accumulator in front of the tank, so the swirl pot can sit where it used to be
