Fuel pump problems ABF
(In Topic #202354)
Mine never primes and I have no problems starting the car, you can bridge the 2 bigger connections where the relay fits to get the fuel pump running all the time to check the pump still works.
Does it run with when you put a bit of wire between the 2 bigger connections where the relay fits?
Have you spoke to the body shop to see if they could fix the fault for you if you think they have caused it?
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
No2 for fuel pump relay, I have No.62 in mine, there is a list of other relays which can fit and they have different rev limiter or may prime before starting.
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrics_2%2Ffuze-box-wiring-layout_2&=
check all your fuses, 17 and 18 in particular again depending on how it was done and what ecu you may have an ecu relay triggered bu one of those 2 fuses
1st check would be the earth, it should go to the white 4 way spade block behind the fusebox. may just have come loose during all the work…
