Fuel Pump Options for G60 Build
Any alternatives to standard GTi pump and accumulator? I don't have anything at the moment so didn't want to start buying parts if there is a (modern alternative) Thanks for any input.
you dont need the accumulator for a g60 so thats the big expense cut. mount the fuel filter where it used to be.
main pump g60 doesnt need anythign special, 75l/hr @ 3 bar is what the early ones ran so anything over that is a bonus. the kjet mk1 pumps are massively over-spec but will work just fine, and tbh arent that expensive aftermarket.
tricky part is gettign fuel to the pump, if you have a good condition mk1 gti tank then fit that, job done. if not then another option is post-84 cab/rocco injection and all g40 shape polo lift pump, but you need an external swirl pot to keep your main pump happy.
