Fuel line fittings remove easily?
(In Topic #230601)
They lines are the braided type lines with a sort of metal sleeve behind the O shaped fitting
When it comes to fuel and hoses my wife allows me to spend as she says a burnt car is worth nothing.
On the drive
Myvalver 89 GTi Grey mk2 16v
On the drive
On the drive
Do you have pictures of final finish.. not that I'm going to do as I'm more concerned with wall thickness, due erosion external(rust) and wear from fuel turbulence over the years.. if I ever get a set of new pipe ill cut and measure 30yr tubes.
On the drive
