Fuel injectors.
(In Topic #216276)
part number 049 133 551 as an alternative to the
steel type part number 049 133 551A.
The brass type seems to offer a cost saving advantage if they are suitable.
Do a search of the forum, hopefully you'll find an old thread on the subject
function wise they work the same, only real advantage is the price, back in the day you could get a set of 4 for less than 50 quid, these days price is similar to the cost of the oem steel ones. corrosion resistance isnt really much of an advantage either, the oem ones last just fine even if the outside gets a bit grotty, its the internals that fail first
https://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-SCIROCCO-STORM-FUEL-INJECTOR-VALVE-BOSCH-049133551A-A888/191630779767?fits=Model%3AGolf&hash=item2c9e15a577:g:PYEAAOSwDNdVo8rn
Fuel injectors.
retail for £20.00 each or thereabouts.
Fuel injectors.
Brass inside engine injectors is that they degrade when using the cheap fuels as they don't have the cleaning additives or is that the other way around.
Friends lexus has prob with injector seals they say oòhfff this is a new head sir…
So he is off to scrap yard to get an injector and refit new brass seals.
Fuel type to degrade brass seals I'm unsure but it was in conversation.
I will check source and reply asiknow
Sent from my SM-G900F using Tapatalk
What's next?
Mk1 second project cabriolet
MK1 first project cabriolet
Fuel injectors.
Ethonal fuel is added as bio fuel at the distributors.
Cheap fuel mainly not premium ie ultimate or vpower.
Ethonal corrodes solder. In carburettor parts so If your seals have soldered components then overtime it corrodes with cheap fuel.
Petrol only
Post from a ' HOP X DUB '
What's next?
