Exhaust leak
(In Topic #243746)
Is there anything I can do more perminant?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I had them weld it to my dual down, and left it Clampable for my cat connection. I also used the solid SS band clamps.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
The problem is getting the damn thing out. The exhaust can't get past the rear axle beam so I can't move it that way.
There is only one join which is between the flange joint and the centre resonator. I managed to slide it out a bit and move the back of the exhaust out a little. Now I need to slide it back into itself. Very stiff…
Whip
/wip/
Noun - Car
/wip/
Noun - Car
The pipe it slides on to seems to have an ID of 2.25 inches. Is that a standard size across the pond?
***edit*** Actually, it seems to be 55mm
There doesn't seem to be a rim for the pipe to slot in to. Perhaps it wore away.
Last edit: by the_whip
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I don't remember the diameters.
You could do what I have done in my MG days and make one out of Aluminum foil. But it is supposed to seal the gap, it look like your system doesn't have enough play in it and that gasket was getting hammered by the ening torque.
You may want yo shim your front valance Cup out towards the engine to prevent torque by using large fender washers between the valance and the Cup to limit the torque.
The rear pipe can slide towards the engine and close the gap, if that's what you mean.
Would you suggest any sort of sealant with a new gasket?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
The Front Grille Engine mount Bolts to the starter, and the has a rubber bumper on it that is pressed on a ball end.
That ball end goes into a cup that is attached to the front Valance.
The Cup is number 13.
Number 15 is a M10X25 bolt that bolts in to the front valance or frame cross bar. Between the cup 13 and the Frame use 2 large fender washers on each side to space the CUP closer to the engine. It limits the Torque shift of the engine on acceleration. Preventing the engine from Pulling on the Exhaust.
The hanger rubber near the flange had also snapped, perhaps that also added to the stress.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Whip
/wip/
Noun - Car
/wip/
Noun - Car
On a Rear wheel drive conventional engine like the Rover 3500 MG's Toyotas, GM and Frog-eye, it was to the left and right of the car.
I can remember my Brother chaining his MGB's Engine to a Bolt on the frame so he could get higher Torque on his wheels at speed starts.
The only real thing that ever botherd me on my Midget, and Frog-eye, (besides the heater at -10F and frosted internal windows and side curtains.) Was the Oil filter as it alway ran down my arm when I changed the oil…I grew to hate filter cartridges…
The new donut didn't make much difference. It might be a bit quieter at idle, but under revs it is the same, if not louder.
I think you must be right about the lack of play. There is a clamp join between the flange and the centre resonator - I'll loosen that off and try to push the back section towards the rear of the car so there is some slack to allow it to move forwards.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
When I loosen the bolts, I can slide the cup forwards around a centimetre before it hits the bung.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I had some issues with it hitting my power steering rack that a oxi-acetalene torch, and a pry bar resolved.
On my second set of Cars, I used the g60 4-2 manifold and a TTtuning dual down on one then used the Down pipe off of a 95 or 96 GTI that had the g60, and the down pipe as the Down pipe had the flexures on it similar to the TTtuning dual down did. I had my Exhaust Guys make the down pipe from the manifold down.
I was wondering about the valance cup and the ball end.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I was just wondering how much space there is normally as the engine is non standard.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I also noticed that rubber ball was worn in one specific position that didn't make sense to me….
So I watched my engine when I had it off the ground on the front. I was finishing some work, and had the front off the ground on stands wheels were about 6-to 10 inches off the floor.
I noticed with the new rear mount that under load the engine was rocking on the front mount more than I thought, and that was decreasing the life of that rear mount.
Ding Ding Ding from a thread I read years ago about folks racing these critters a solid mount for the front.
As I am the proverbial Cost Effective Illigetimant Son of my Mother.
Instead of sending my monies on a solid block of Billeted aluminium, for a teeth crunching ride, I opted to
Decrease the spast of the Front mount while keeping my
rubber insert. Less travel for the engine, and a bit of cushion for my teeth.
As I was rocking Auto's I had more torque less loss on the first and second shift of my transmissions. Less rattle of my exhaust.
I added a couple of M10x25 on each side, but they are quite thin so there is still quite a gap. Maybe I'll add a couple more.
It looks like this without any washers…
The flange issue is definitely sorted now. I got a new muffler which is supposed to be "ultra quiet" but is basically the same as the old one.
I can't fit a stock exhaust as it's a Corrado engine. Maybe I could add a short chambered thing to my ultra quiet thing.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
