Erratic idle when cold
(In Topic #192635)
92 mk1 cab GTI
Car starts fine place key ignition fuel pump primes etc,
However the idle was jumping below 500 to 700 for 5 mins slight foot on accelerator smoothed it out no misfire. During warm up I could hear a slight thumping/tapping noise from tank or maybe accumulator, like an air lock, actually it sound more like gloop gloop noise if that makes any sense lol. Is this noise normal during start up ?
How can I check the in tank pump is working fine because I also do notice the main pump whine is still quite audible even during driving.
Could the filter on the in tank pump be mullered ?
I have read about AAV valve but is that not normally with high revs after warm up?
How often do the AAV stay stuck in closed position even when warm ?
Thanks in advance
to get to the lifgter remove the seat base and theres a black metal disc, take that off and theres your lifter pump
