Braided pipe Fuel supply to filter and engine cutting out problems.
(In Topic #203955)
2001 Zafira 1.8
2001 Zafira 1.8
To remove the old one can you get anything between the bolt and filter to help lever it out while undoing it in case the threads just need to grip a little?
http://www.classic-vw.co.uk/fuel-pipe--fuel-filter-banjo-bolt-n90358003-8130-p.asp
To gain access to lift pump/sender you need to get a metal bar and hit it with a hammer on the edge to losen it, it only needs to move alittle to remove it.
Pictures.
I use a T bar from my socket set.
You only need to knock it around this far to remove it,
You have to get all this out of the hole so go carefully.
You can then fish about in the tank with a magnet to collect bits of rust then I left my magnet in there to collect anything else.
Check and clean the little filter on the end of the lift pump.
I have placed six strong magnets at the bottom of the tank, hope this draws some rust in. What do you think about the
fuel filter pipe just turning when loosened?? Its still in a sealed position yet I can turn it but it doesn't loosen?? Got me stuck that one.
Just seen Mark1gls post. Brilliant pics and info mate. A big help when you see what is inside the tank. I thought the braided pipe was
all one unit great to know I can get the separate threaded banjo piece. Once I source a new one I can attack that side.
Cheers for the info lads.
Last edit: by FLOGIT
good luck!
2001 Zafira 1.8
2001 Zafira 1.8
Have a cloth handy when removing the fuel lines as petrol will come out and make sure the car windows and doors are open.
Also be carful not to lose the rubber fuel lines from the inspection hole and you may need new jubilee clips if they not been removed before as VW fitted crimped ones when new, fit fuel pipe jubilee clips (like ones in my pictures) as normal julibee clips will squash one side of the pipe and can cause a fuel leak.
With the advice it came off in quick time. Carefully removed it to find no filter on the end? Flash light in the tank no sign of it…..its a big tank though with a very restricted view. A few specs visable not sure what they were?
Piece of wire and a strong magnet, moved it around and picked up nothing.
Will I be able to buy a filter?
I'll have a look in a garage to see if I've still got an old lift pump with a filter on as I've been through 4 pumps since I got the car 20 years ago…
