Bike Fuel Pump - Tank Connection
(In Topic #218058)
Pump In/Outlet - 10mm
Existing lines - 8mm (?) How the hell do I go from 15 to 10, can't seem to find anything
ie:
5/16" x 1/4" Stainless Steel Barbed Reducing Coupling | U.S. Plastic Corp.
The in tank pump on the GTI set up might be a problem as usually bike carbs run at very low pressure.
But assuming thay isn't a problem.
Where are you mounting your pump and which one are you using? I only ask as I've been through the ebay £20 specials and it failed. I also went with a Facet 'small block' pump which also seems to be having trouble and have now bought a Suzuki 1100 original bike pump to try.
Either use reducers
https://www.ebay.co.uk/itm/Metal-Hose-Joiner-Barbed-Steel-Connector-Reducer-Fitting-Air-Fuel-Water-Oil-Pipe/121691704476?hash=item1c55640c9c%3Am%3AmDELar2qZsJzhLwxxjumPGA&var=420694380568
https://www.ebay.co.uk/itm/Brass-Hosetail-Reducing-Connectors-Pipe-Repair-connectors-Reducing-Hose-tails/121368740932?hash=item1c42240444%3Am%3AmCVPUFrcg9lK2KZifJn5zFg&var=420311591046
Or alternatively you can use re-useable fuel filters
https://www.ebay.co.uk/itm/Inline-Low-pressure-petrol-fuel-filter-classic-car-6mm-8mm-10mm-1-4-5-16-3-8/121225309652?hash=item1c39976dd4:g:534AAOSwWiBaz1zo
By buying a couple you can reduce as you wish but not have lots of reducers around and filter the fuel too!
I'm surprised the tankl outlet is that big as I would have expected it to be the same as the fuel lines.
I only know non GTI tanks and lines and they all have 6mm lines and outlets from the tank so I can't help there I'm afraid
Ian
