Are these suitable O Rings for my injectors?
(In Topic #190579)
I need to replace the O rings on my injectors. At least one is leaking fuel from around the brass holder.
I found these online:
https://au.vwheritage.com/vw_spares_Fuel-injector-seal-Upper-K-Jet-034133557E_act_shop.product_pID_108661504.htm?crumbStartPage=2&crumbStartRow=17
But I am not sure if it is the correct part. I (am pretty sure) I need to replace the green ring in this pic:
the ring on the site looks too small to me.
Can anyone tell me if it is the correct part before I purchase?
These are the seals that I bought and will get fitted soon with my new injectors.
If no air hose then you need the other type.
Digifant is a completely different injection system.
No because there was slight changes to the engine fuel system and other things over it's 12 ish years it was used. Most changes can be seen by looking so really easy to tell which type you have.andyphill said
would you not be able to tell by the engine code, like dx for the 1.8L, i want to change mine and was going to go down that route.
Massbad69 said
http://pages.ebay.com/link/?nav=item.view&alt=web&id=221233249484
Thanks mate,
Decided to go with these ones
the injectors from the dx head are nearly new along with the seals so HOPEFULLY the seats come out ok..
thats the plan anyway no doubt there will be another speed bump or 2..
1983 mk1 gti white bought as a daily now in pieces..
