5th Inj woes again
(In Topic #165117)
At wits end now
Now car won't start. So put 5th Inj into coke bottle crank nothing .! Ok let's check voltage at I Injector 12v 12v 12v 0v 0v
Any ideas why this would happen .??
Lee
2001 Zafira 1.8
2001 Zafira 1.8
Should state
Filler necks new
Main fuel lines new
New bosch pump
There's spark but no it doesn't start at all
Were could blockage be .??
Lee
2001 Zafira 1.8
2001 Zafira 1.8
Thought I'd try jam jar test so bridged the relay then thought strange pumps not buzzing checked def 12v getting to it so removed it , full of crud .!!
But crud isn't metallic rust like your thinking its more like rubber .!so I think the brand new filler neck hose. Had perished inside
Hope this helps.
Lee
2001 Zafira 1.8
2001 Zafira 1.8
Was the little 90 degree pipe I'd made up. It scraped inside and the rubber shavings blocked the pump inlet
