1983 mk1 running issues
(In Topic #188931)
Help plz!
if it runs better with the system pressure artificially lowered (pipe cracked loose) it could be incorrectly adjusted/sticky air flap, pressure regulator fault (if same on 2 metering heads probably not) fuel return to tank blocked, fuel lines to WUR blocked, faulty fuel injector(s), mesh on WUR fuel inlet blocked, or a faulty WUR
have a look thru this thread, ignore the 16v specific bits just concentrate on the basic kjet tests. also with ignition timing this is done at idle with dizzy vac pipe disconnected and plugged:
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
