1457 1983 GL with weber 36TLP conversion requires choke
(In Topic #204375)
Now it runs, idles fine, full throttle is fine - but part throttle requires 1/4 choke otherwise it misfires, cuts out and generally just doesn't run.
Inline filter is clear, albeit mostly full of air even after running for 10 miles and an hour.
Going to replace the fuel lines in the engine bay along with all the vac pipes (but they are producing vacuum at the ends).
Any other things to check?
Cheers.
Edit: Changed carb to 36TLP
Last edit: by Congruent
It might be timing, worth checking. But also worth checking is the tune on the carb, you need at least a CO meter to do this but ideally an AFR meter and a rolling road run. Its completely possible that it will have the wrong jets in the carb for your engine, for example.
Pumping the throttle puts more fuel in (via the acceleration pump) so it might be lean, but without the intruments its a complete guess.
The mixture is adjusted by a small screw which is recessed on a slight angle fitting on the front left of the carb, if its the Weber I'm familiar with.
I assume the timing hasn't been changed (I wasn't around when the work was being done) but I've ordered a timing gun to check.
Have you looked at the spark plugs and/or changed them? If you do, clean out then spray plenty of WD40 or similar into their holes (while they're there) because they can get rusty and snap in the head, which obviously makes removal awkward.
Also would be worth closely looking at the condition of the ignition leads and a check inside the dizzy cap etc, not sure if a 1983 will have electronic ignition by then or have points.
(I.e. there is a sticky out rectangle block then a diamond cutout, I assume the rectangular block is TDC, is the diamond the correct BTDC?)
All plugs look fine, leads were brand new.
Edit: Carb is actually a 36TLP, not a 32/34!
I'm going to change all the vac pipes and fuel pipes next time. I used some carb cleaner to see if there is a leak but didn't find one…
However it does hesitate under full throttle, so which jet is the cruise/main jet on the 36 TLP? I can't find anything useful on it!
Just want to take it apart to give it a damn good clean to see if I can sort it myself.
All very well buying the jets but without knowing where they go… not so useful!!
Cheers.
Took the carb half apart and blasted it with carb cleaner, it was full of fuel so I don't think it is the pump.
25% of the tank is 4 year old petrol, 25% of the tank is new and 25% is year old.
So we are thinking bad fuel now, so going to run it with the choke on which should burn some of it.
I think if I need to fiddle around with jets I'll just get a kit of various ones, then take the carb apart and see what goes where etc.
Its that or a rolling road session (or two) with someone who understands carbs as well as EFI etc
100 miles with choke out should burn a decent amount of the tanks (not a bad thing need to empty to replace the filler pipe!)
If however new fuel doesn't fix it then I'll look at stripping the carb again.
mark1gls said
If running the car with the choke out you may need to clean the spark plugs once you finish as they will be black and covered in soot/un burnt fuel?
It depends, if the car's already running lean then a slight adjustment of the choke can enrichen it and could either bring it to correct AFR, or go too far and send it rich. In days gone by people would pull the spark plugs and judge by reading (looking at) them. Nowadays, one would use an aftermarket AFR meter. Running lean is more dodgy than running rich due to detonation and possible engine damage. If too rich, you'd "bog down" before any further damage although massively too rich could wash the bores of oil and lead to greater wear there.
Really you need to get to grips with if the car is too lean, right, or too rich. Aim for 14.7 at idle and 12.5-13.0 above 3000rpm or so at wide open throttle. Sometimes you can go a little on the rich side and advance the timing a tweak more for better power too.
Sniper EFI Self Tuning Kits - No Laptop Required
They may do it and tune the car for beer money?
I bought a 2nd hand CO2 meter from ebay for £40 as it's close enough to get my car set up, it's not going to be as accurate as a £1000 garage one.
One like this…
http://www.ebay.co.uk/itm/Gunsons-Gastester-MK-2-MOT-CO2-Emmisions-Tester-/262436941361?hash=item3d1a75ee31:g:NgIAAOSwSgJXN0p2
mark1gls said
Pop in to a local friendly garage and ask them to put the car on there CO2 machine (as used for an MOT)?
One like this…
- Its CO, not CO2 but its a common error these days.
- Its really only useful at idle, these types of DIY meters are only designed to cope with the gas flow at idling. Rev the car up a bit and it will not read properly. And try hooking it up during running (ie under load) and you'll get nothing useful - the reading needs to be a steady state one, its far from instantaneous. Also it won't tell you how lean you are on the lean side - CO basically drops to about 0.1-0.3% from just lean of stoich to the lean misfire limit. It does correspond not-too-bad on the rich side though.
As said before, you really need some kind of AFR meter to properly set the car up.
