1.5 carb engine - what is this green thing meant to do!?
(In Topic #234079)
It goes to a three way split, which runs to a breather and another breather. It's entirely disconnected from the entire engine. What should it do and where should it be connected?
Last edit: by Volks42
Regional Host NE
nicci21paul said
vacuum storage unit
Where should it be connected to the carb? All the pipes on mine are already on use, I can't see where to connect this object.
Sent from my H3113 using Tapatalk
Malcolm said
Depends on the type of carb fitted. If original it is connected to a Pierberg1B3 carburettor. If an aftermarket Weber is fitted, I belive this item is disconnected and not used.
A
