water pump
(In Topic #204289)
water pump
2001 Zafira 1.8
2001 Zafira 1.8
As above, the bolts are prone to snapping so take extra care to not let them otherwise it becomes a more involved job.
I do it all from the top. Save for having to take the power steering pump bracket off if installed.
Here is how I do it.
How I change out my Water Pump | Volkswagen Owners Club Forum
I strongly suggest that you remove the housing and then remove the pump from the housing, because if it hasn't been
removed in a while then yours may have corroded bolts, and it doesn't take much to shear a bolt head. 6pt sockets only.
Also you may want to take one bolt out at a time on the new pump and place never-seize on the bolt, then retighten it to 9.2nm or 87 in/lbs.
After you get all the bolts never-seized, spray the back side of the bolts with battery anticorrosive spray, this way they will never ever be a beeatch to remove.
No never-seize and a 20 year old pump…. This was one of my spare housings…..I was gonna clean and install my new pump on….. That was a 1/4 drive 10mm socket and a 1/4 ratchet with a short stroke handle, and very little umph.
Good shout getting the whole unit, looks a lot nicer in the bay too!mark boag said
well took the old pump off 34 years old original one! good job i replaced the complete unit as the nut that holds the lower cam belt cover to the water pump snapped off . not a bad job to do if replacing the the complete unit. RECOMMEND REPLACING COMPLETE UNIT! Thanks for all the advice.
