Help
(In Topic #201085)
1987 gti cabriolet
Terrywoo1973 said
FYI ?
The FYI means that if no one comes up with the answer first than John (rubjonny) might know.
part number is 049103499G, NLA from VW unfortunatly.
rubjonny said
vacuum connection for the air shrouded injectyor system. if its snapped block it off to stop an air leak and carry on.
Cheers John!
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
check timing markers as per this thread but ignore all the setup procedures:
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14915
fior ignition timing this is done at idle with vac line to distributor disconnected and plugged, co is done with the car sat at idle, no connectors to unplug but the breather parts apply if the oil is heavily contaminated
try http://www.busdepot.com/049103499g
http://www.mtl-autoparts.com/apps/frontend/templates/index.php?Type=items&make=VOLKSWAGEN&year=90&model=GOLF&partType=Crankcase+Breather+Connecting+Pipe#.Vk7-YXbhDIU
also try www.fcpeuro.com & see of they can source one for you. Good luck…
