Help
(In Topic #201085)
1987 gti cabriolet
hi does anyone know what this part number 24 is called, or where I can get one , many thanks
Anyone help
FYI ?
Terrywoo1973 said
FYI ?
The FYI means that if no one comes up with the answer first than John (rubjonny) might know.
vacuum connection for the air shrouded injectyor system. if its snapped block it off to stop an air leak and carry on.
part number is 049103499G, NLA from VW unfortunatly.
Cheers John!
Thanks John it's already sealed off but my car running very rough and trying to get to the bottom of it
check all the kjet basics as per this thread, ignore the 16v specific parts:
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
check timing markers as per this thread but ignore all the setup procedures:
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14915
fior ignition timing this is done at idle with vac line to distributor disconnected and plugged, co is done with the car sat at idle, no connectors to unplug but the breather parts apply if the oil is heavily contaminated
Hi bud.. you may have to source a new part from the States or elsewhere… then you got freightcarrier charges & the good ol' government Duty/VAT import charge to consider too…
try http://www.busdepot.com/049103499g
http://www.mtl-autoparts.com/apps/frontend/templates/index.php?Type=items&make=VOLKSWAGEN&year=90&model=GOLF&partType=Crankcase+Breather+Connecting+Pipe#.Vk7-YXbhDIU
also try www.fcpeuro.com & see of they can source one for you. Good luck…
p.s.
rubjonny
is a VW legend
