Window switches act slow or not at all?
(In Topic #218974)
I took the switch assembly out and removed the bezel and rocker lever and then dropped the unit in my ultrasonic cleaner . I do motherboard level repair and so I use the cleaner all the time on boards. I also use ultra pure water. it's 18.2 megs and theoretically the cleanest water one could get. It doesn't conduct electricity and tends to lift dirt and corrosion of a medium to make up for it's slightly negative charge. Combine that with a good cleaning agent and you have a great cleaner. Anyway, the switch works just like new again. no issues at all.
If you have an ultrasonic cleaner you might want to give it a try.
However: Hint Big Hint….
If you clip the Brown/white Ground wire to the controller (drivers door open), your controller will operate with the key out for 15 minutes, if you are like me and hop out so fast that you forgot to roll up your windows.
Other wise if you have your keys out, and forgot to roll the windows up after you have opened the door, you have to put the key back in and turn it to run to roll up the windows… Cut the brown/white wire, and you have 15 minutes of power to the controller whether the key is out or not.
