Which Ignition coil
(In Topic #240759)
I need to replace the coil. My car was originally a 1.1 but now has 1.5 jb engine fitted and I would like to know do I need a coil with a built in ballast resistor?
Sent from my SM-G973F using Tapatalk
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
I think there's also a purple wire somewhere near the coil and if you have it then it's a ballast resistor type.
I'm not 100% so maybe some wizz with electrics can help…?
I had to check with type I had when switching from contact points to electric ignition.
Which Ignition coil
Which Ignition coil
Have a read of this
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrics_2%2Felectronic-ignition_16
Which Ignition coil
Re:
Thank you, will domark1gls said
Found my old thread when I was checking my coil and rubjonny came to the rescue.
Have a read of this
Re: Re:
Have a read of this
Link seems to work for me?
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrics_2%2Felectronic-ignition_16&=
If not Google Mk1 Golf electric ignition and the post was from June 2013 on this website
