Which Ignition coil
(In Topic #240759)
Hi,
I need to replace the coil. My car was originally a 1.1 but now has 1.5 jb engine fitted and I would like to know do I need a coil with a built in ballast resistor?
Sent from my SM-G973F using Tapatalk
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
It's been years since I had to check which coil I had but if you have a Haynes manual there's a test you can do with a multi meter to check the voltage.
I think there's also a purple wire somewhere near the coil and if you have it then it's a ballast resistor type.
I'm not 100% so maybe some wizz with electrics can help…?
I had to check with type I had when switching from contact points to electric ignition.
Which Ignition coil
Thanks for your help
Which Ignition coil
After some more checks I believe my vehicle needs a ignition coil designed for use with a ballast resistor although I can't find a resistor or resistor wire on my vehicle. Im thinking of fitting my own in-line ballast resistor but I'm insure what ohm rating resistor I need to fit. Any help would be appreciated
Did you find the purple wire?
Found my old thread when I was checking my coil and rubjonny came to the rescue.
Have a read of this
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrics_2%2Felectronic-ignition_16
Have a read of this
Which Ignition coil
No sign of a resistor wire or ballast resistor currently fitted
Re:
Have a read of this
Re: Re:
Have a read of this
This any good?
Link seems to work for me?
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrics_2%2Felectronic-ignition_16&=
If not Google Mk1 Golf electric ignition and the post was from June 2013 on this website
