What o what did these wires go to?
(In Topic #232505)
Evening all . So there was a KJET dx system in my cabby. Now have a digi . What components did these go to
I think the wires are….
1st picture, the white plug with the yellow/white and brown wire is front fog lights but I guess you don't have them, VW fitted that wire in the factory. So just leave it there.
2nd picture, wires to the starter motor solenoid.
Thanks Mark i will label up the fog connector . The black one would be for the old cold start system ?Abit confused on the thick Red,black now .https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Fgti-1-8-starter-motor
Last edit: by FXTURE
I must point out the Replacement engine mk2 Digi isnt wired up running yet . Just wanted to identify the Red black heavy guage wire and its importance. Cheers
yes 1st plug is front fogs, chunky red/black is main cranking live. the black wires are left over from the old cold start system you can chase it all back and remove
Thanks Jonny and Mark.. Mystery solved then..Thanks for your input on this !!
