What alternator do I need
(In Topic #233194)
Does anyone know which is the correct alternator for a 1.5 engine?
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
I know that when I replaced my oem alternator on my 81 Golf Diesel I had a rebuilder take it from the 50 or 60Amp to a 90Amp.
I also had to run a new cable to the battery as I went from the Motorola plug to a ring connector.
I went from a 660CCA battery to a larger 1200CCA battery, and wanted to make sure that I could charge the battery more efficiently, and the 1200 sure made starting the diesel on cold mornings more enjoyable.
I did have to modify my radiator shroud a wee bit
When the Battery guy tried to install the new battery it was about 1 to 1 1/2 inch longer than the old, and I marked the shroud, then removed it and Beat a nice Ding to accommodate the new battery size.
I got 10 years out of a 5 year battery…
