Stereo losing radio stations every time I remove the ignition
(In Topic #239831)
When I bought the car, it had an old JVC head unit, and every time I took the key out the ignition the radio stations would be lost. Assumed it was the head unit so bought a new one, and have the same issue!
It's going to be a simple wire to the wrong connector I'm sure, but I want to do it right… can anyone point me in the right direction of a diagram or solution please?
All the memory is lost - time, radio stations etc - so it's going to be a case of there's no permanent feed to the stereo?
Thanks!
On after market radios it is a Yellow wire that you have to go direct to the battery.
The Red wire is for the switched power which I usually grab off the hot side of the Defroster switch Black/Yellow wire on the connector side.
see:
https://www.cabby-info.com/Files/AudioSystem.pdf
Briano1234, Great link, I have just printed it for future reference.
