Starter motor brushes
(In Topic #230083)
Anyone have a good source for starter motor brushes for a Bosch starter? Stripped it all and the brushes are low, 8mm at best but i can only find ones that are 25mm long. Seem too long.
Size is 5mm thick, 12mm wide and whatever the length should be
I dont have the part number at the moment, its at work soni cant compare part numbers
Last edit: by Bradcab
here are the pns for a 89 Cabriolet.
I got mine off ebay using the part vw part number. You need a hefty soldering iron when putting the new ones in, and getting them all out the way when you re-fit the commutator is fun!
Ive already predicted that paceman so ive come up with an awesome use for the soldering gas lid…slides right onto the commutator
That is a neat idea, I would of used a cap and drilled a hole in it the size of the shaft so that as I reinsert the thing it will hold then and be pushed out at the same time the shaft is inserted holding all in place.
You can tie a piece of string to do that as well. Snip it when the thing is in place and work it out.
It just slipped right on brian without a hole drilled. Its the same width as the commutator so worked a treat without all the fiddling.
Cool....
