Spotlight removal?
(In Topic #242219)
Hi.
Does anyone know a way of removing the inner headlamps from a clipper grill without breaking the clips?
Thanks.
Thanks.
Thanks for that, I'm still trying to get my head around it. It's more involved than I expected.
The issue that I saw when I made the how to, were the nylon Keepers, they become brittle and you can't turn them or twist them until the screws or adjusters are out.
I haven't had the luck to find the partnumber of those to search them out.
Yes, the white nylon bits broke up on my originals as I was trying to remove them, I've got another grill so trying to get them out without breaking them this time.
Once you get the center pin out, then with a good penetrant oil spray them, and slowly wiggle them back and forth to free then then if you look you will see a ramp on the bracket, you have to get them to go over the ramp to unlock them.
The center pin has to be remove to allow then to decrease the diameter a wee bit as it helps to spin them out.
