Spark Plugs?
(In Topic #223282)
Evening gents.
Are these plugs ok for my '85 GTi?
(DX engine is it?)
(DX engine is it?)
Download the app called repxpert register for free it has a free vrm lookup then you can see all parts available for your car. Fantastic tool 👍
When I am not buying parts I will be looking 😆
I didn't really get my answer from there unfortunately. Thanks though.
Any thoughts?
Any thoughts?
What's your reg number I will check
B732NOY.
Just used my reg as it is also a 1.8 DX and yep those plugs are listed 👍
Brilliant. Thanks mate!
Just checked your reg to confirm yep same listing as mine wr7dc+ are spot on 👍
Spark Plugs?
I always use multi point in my DX I find it runs smoother and better than the single point
I had bad luck on 3 different sets of Bosch over here, 2 bad in one set, and 1 bad in another…. The original issue was a BAD HV lead, but it got worse before getting better. I was glad to have a Spare good running car, so swapping out the plugs and wires proved what was up…
Took longer than I thought it should of.
I have switched over to NGK, and found my Cabbies really really enjoyed the change.
