Restore horn
(In Topic #221574)
So it's just ground and voltage cable from the horn connected to the button.
So how do I go about restoring the horn so I can use the button on the steering wheel?
Restore horn
The twin horn on earlier cars pre 1990 tend to suffer current drop across the twin horn set up. The old wires goes higher resistance.
On the steering column there’s a horn tab and a ring on the underside of the Steering wheel.
This allows continuity of the wiring from the horn pad.
The current path goes down through the column and is linked via a brief wire that bridges the column and steering rack.
Bear in mind that these horns are negative switch and permanent live.
Verify that you have 12v on the black/yellow wire going to the horn. Yes then proceed testing the horn, no and you have to find the fuse or the break in the wire preventing 12V full time.
Verify that you horn works by taking a wire and touching the brown wire at the connector to the frame.
Verify that you have a Ground wire from the left hand steering rack bracket to the side of the Steering gear box….
Ground from the mount goes to one of the horn buttons from the center of the steerin g shaft to the horn relay that switches the ground to honk the horn.
Restore horn
But it seems I have dual horns so just the louder horn is rewired to the red button.
Should there be two spade connectors coming up the steering column?
Restore horn
I've got round this problem in the past by just running one horn. Eventually fixed by replacing both horns.
This might be why an alternative switch and circuit was wired in ?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
On my 81 Diesel bunny, I decided to take the Beep-Beep and install a dual air horn….. Made folks know I was around.
As said they are very prone to not working and are a relatively complicted setup compared to the rest of the world (a switch to horn to earth) VW earth the switch on steering wheel thats then earthed to steering column\rack exposed to the elements under the car and then to the horn via a relay (which has its own +ve and -ve supply) +ve live is fed direct to the horn, not sure if this is ign live or all the time?. This confuses most spanner monkeys who then come up with ever more ingenious methods of othercoming the problem eventually ending up with a new switch-horn-earth circuit……
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Cheers.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
