Removing fan blower from top?
(In Topic #189078)
How to?
He was blowing fuses associated with the interior fan/blower (the fan that sits in the scuttle).
I have found that it was seized and after much WD40 I can only get it to turn a small amount with a fair bit of pressure so it will need replacing.
I did see someone post a little while back that it is possible to remove the fan unit from above. .
Please could someone let me know the process.
Dan
I have done from above, remove plastic rain tray, remove wipers (3 x 10mm nuts?) remove the couple bolts holding the plastic leaf basket and blower and then juggle the blower out. It is a bit of a krypton factor challenge but it can come out from above.
next I jumped the fan motor itself with 12v straight from a battery bypassign the resistor unit, to stop it blowing fuses and provide the motor with maximus power (keep an eye on power wire and disconnect if getting hot!) then as its spinning spray more penetrating oil at the bearings till the motor is spinning up lovely and fast. once happy, drown the bearings with silicone spray lube while it is running to lube it up nice
il going to be checking it tomorrow,
1 fuses
2 replace switch
3 lube motor from the engine bay - am i following the correct format here? - http://www.cabby-info.com/Files/ReplacingTheBlowerMotor.pdf
is there anything else im missing?
1983 Diamond Silver Mk1 GTi - Black Leather Interior - 16V ABF - Cable box - Upgraded Servo/MC and 280mm Disks - Coilovers - 15' Melbers
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Fheater-motor-removal_2&kfs103=30
