Removing fan blower from top?
(In Topic #189078)
How to?
I'm helping a fellow member from the club with a few issues on his Golf.
He was blowing fuses associated with the interior fan/blower (the fan that sits in the scuttle).
I have found that it was seized and after much WD40 I can only get it to turn a small amount with a fair bit of pressure so it will need replacing.
I did see someone post a little while back that it is possible to remove the fan unit from above. .
Please could someone let me know the process.
Dan
Dan
There was a big argument ages ago about whether it possible from above or you had to remove most the interior and dash and do it from inside the cabin.
I have done from above, remove plastic rain tray, remove wipers (3 x 10mm nuts?) remove the couple bolts holding the plastic leaf basket and blower and then juggle the blower out. It is a bit of a krypton factor challenge but it can come out from above.
The is a post with picks in the "how to" section that I used last week. A bit fiddly to split to cover and wiggle the pieces out but probably only an hour job.
when i did this i drowned either end where I suspected the bushes were with lots of proper penetrating oil (not wd40, this isnt what it is for!!) and kept wiggling the fan blades back and forward till I felt it free up some.
next I jumped the fan motor itself with 12v straight from a battery bypassign the resistor unit, to stop it blowing fuses and provide the motor with maximus power (keep an eye on power wire and disconnect if getting hot!) then as its spinning spray more penetrating oil at the bearings till the motor is spinning up lovely and fast. once happy, drown the bearings with silicone spray lube while it is running to lube it up nice
Getting it out the top is easy enough if the unit is scrap. Getting a new unit in from the top whilst not breaking it proved too difficult for me so I removed the dash and did it from below.
you can do it I did I not saying it is easy but it can be done the trick is dismantling the plastic cover from the fan while it still in place the same applies for fitting the new one......PM me and I will give you my number and talk you through it,,,,,,to long winded to write
i need to "service" my fan asap, it went from working well at all speeds to working at very low speed.
il going to be checking it tomorrow,
1 fuses
2 replace switch
3 lube motor from the engine bay - am i following the correct format here? - http://www.cabby-info.com/Files/ReplacingTheBlowerMotor.pdf
is there anything else im missing?
1 fuses
2 replace switch
1983 Diamond Silver Mk1 GTi - Black Leather Interior - 16V ABF - Cable box - Upgraded Servo/MC and 280mm Disks - Coilovers - 15' Melbers
This may help, I did this a couple of years back the exact same way:
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Fheater-motor-removal_2&kfs103=30
Just removed the fan assembly on mine, pretty easy to do from engine bay, fan was seized just sprayed up and ran directly from battery. Another one crossed off the ever growing list of jobs to do!!!
