Red light flashing after dash lights stop working
(In Topic #216070)
I would validate that you have 12V battery on pin 14 black of the cluster. Verify that you have ground on pin 2 brown.
and that pin 2 is 12v to pin 14.
The middle leg of the voltage stabilizer is ground, make sure that that and the pin 2 are the same.
The other two legs are 12V battery from pin 14.
And the remaining leg is @9.5 to 10v.
If that is working then your issue is a cold solder joint on the water temp gauge. I have how to's that may help you in the Archive Section How-Tos.
View topic: My DIY list of things for a 90ish Cabriolet (digifant2) part 1 - The Mk1 Golf Owners Club
under the electric.
1990-1993 repairing your flakey water temp gauge.
86 is the same.
gauge, as it has power in from the 10V stabilizer
Ground from the ground, and the input from the sender.
So if the sender has been replaced, and it happens well, then I suspect that you have issues inside the gauge itself, as that is where the circuitry is for setting the light off.
The top leg off the gauge is the flashy flashy light.
With these Critters, I suspect the grounds first, and the
Gauge second…. but in 4 of 4 cabbies I have owned, (89, 90, 92 and 93) I have had to resolder the connections on all of them inside for cold solder joints….
If your gauge studs are corroded, then you will ned to polish them up….
The thing with 80's electrics, is it voltage sensitive….a little as .25V can set circuits off.
If you have changed everything and added a piece of tape behind the mylar to Plump It up to the connector.
If you have added a frame ground to pin 2 as in splice it in. You are left with it being internal to the gauge.
