Random wiring questions about g60
(In Topic #216538)
1. I need to wire in the lift pump can I use the the loom out of a gti cab and just swap over the loom from the Jetta as Jetta is carb model so only has 2 pin sender instead ?
for the cabrio it also has the 3 pin level sender, to bring that over chaser the brown wire to source i think it goes to the earth claw above the fusebox. if it does, great just pull that out as well.
the purple/black a bit more tricky, this goes to the fusebox. these pins are a real git to remove, so what you may find is easier is to depin it from the 3 pin plug, swap the old wire ion. its a 2.8mm latched spade, pretty easy to get polevolt do them or mark carter at classic-vw can probably supply.
or you can just cut n splice if you prefer. mark can do you a ce1 pin tool as well, if you wanted to depin the purple/black fusebox end and swap it
