Problems with Speedo intermittently working
(In Topic #238874)
I replaced the cable as it was a bit worn through, but the new one has similar issues. Sitting on the drive, if I fully home the cable to the back of the gauges, then manually turn the red gear on the other end, it won't move the Speedo needle. If I loosen it and jiggle it a bit it works again.
I guess the back of the gauge is loose or faulty, but I've yet to pull it out. Is it something common that can be fixed or will I need a whole new set of gauges?
Here is a topic which hopefully be useful to you which I participated in.
View topic: Odometer gear replacement – The Mk1 Golf Owners Club (vwgolfmk1.org.uk)
Malcolm
Malcolm said
Hi, this is a common problem, I had the same issue.
Malcolm
Heh, that was my post originally. This issue isn't the odometer that seems fine, more the actual speed gauge/needle doesn't move off zero until I've been driving for a while.
