Printed circuit foil
(In Topic #208539)
https://www.werk34.de/product_info.php/info/p19935_Printed-circuit-foil--for-Golf-MK1-Cabrio-1983-92--with-Airbag-and-MOTOMETER-Speedo.html
over the years i collected several clocks and for my restoration, i made a good set of MFAs from several pairs. during transportation from one place to another a nice mechanic left that set hanging from the steering column where they were eventually smashed to smithorines. i bought new casings to repair it but it had to much internal damage and did some pretty made things.
i had other bits left to make up a ok set of non MFA, the only down side is that only one bulb works in the top part of the clock, has anyone tried using the werk34 printed circuit foil?
i also saw you could buy conductive pens and retrace the copper lines anyone tried this?
Now the issue with Mylar/copper foil runs is that it can be very brittle over the years and delaminate.
It is the lamination that gives the copper foil strength.
I clicked on the link, and I have to ask it says Cabriolet 1982-1992, with airbag and MotoMeter speedo.
Over here the Cabriolets didn't have airbags until 1990.
They also switched to MotoMeter speedos in 1990 as well. So if that really works, the it would surprise the hades out of me.
The Face of your Speedo will say VDO or MotoMeter.
Here is the US VDO face:
MotoMeter Face:
I personally would be leary if you have the VDO gauge set, and no Airbag. Although the Air Bag is just a couple of LED's and shouldn't be that much of a show stopper.
I have repaired Mylar Foil Breaks in the past by Carefully scraping the Mylar off the break. I then used Epoxy To Stabilize the tear, and Painted over the lines with the conductive paint. While it did last for a good long time on the car I did it on, Sold it after about 1 year, so I can't tell you the longevity of it. You may have to use a couple of passes of the pin for total coverage, and don't cross lines.
I have also Back Fed circuits on the cluster by attaching 12V and Ground to the 10V stabilizer, to the pins on the connector side. I have a how-to on that in the Archive Section.
Now in the parts stores over here they sell a "Permatex" Professional Defroster Repair Kit. In that kit comes "conductive paint" in a small vial and a brush, along with Conductive Glue. The Glue is to repair the Broken Tabs off the back of the Glass.
With the Conductive Pen's and or Conductive Paint, you may have to build up areas, and I would suggest that after the repair of the mylar that you use a good Cellophane Tape (3m) to again stabilize the repair to the existing mylar…
If you also look at the connector of your cluster (under the shroud) it is labeled as to what the pins do.
So if you go with the new versus the repair, you may have to move some pins around, which isn't that hard to do as the connectors are hinged on the sides to allow insertion or re-positioning of the pins.
Taking the shroud off the connector and placing one strip of electrical tape on the pin side of the plastic tongue.
I have also had to use "Super Glue" to re-glue Foil that have come loose from the mylar.
I would see if they can take a photo of the Mylar Connector as to the pins so that you can compare theirs to yours. Prior to the install.
http://www.oemepc.com/
Just looked at the ETKA
155.919.059 with MFA
155.919.059A with shift light
155.919.059B Conductive foil (assume VDO)
155.919.059G Motometer/Airbag
My connector is a 14 pin with some empty slots.
Car is 82 1.5GL.
Thanks for any help
J.D
It is a tool that has a tongue and a push rod that you place in the front to unlock the catch and then a pusher that will push the pin
out the back. I have had to on occasion take a paper clip and flatten it to use as a lock pick, then wiggle and pull the pin out the back.
For pins they used to sell them at tandy/radio shack over here in the States, and there where a couple of Electronics parts stores that sold them.
I have even seen them at a Computer Store that had a "Robot/Drone" section.
So all you need to do is to source the pins. Since you don't have the Pin crimper you would strip a bit of the wire and solder it to the pin, then
bend the crimps over a to clear the way to insert it.
Just thought I could open the connector which would make it a lot easier.
JD.
I was hoping that was the case, as it looked like it was in two parts, but I did not want to force it.
J.D.
