Pin out mk2 dash
Hi, can somebody help me with a correct pin out? I'm changing the wiring loom, in a cabby but the wires all white except one. Here's the pics
thats a mk3 golf clock loom, if you're using mk2 clocks you'll need a mk2 clock loom to match as its slightly different pinout. on the plus side with the mk2 loom all the wires will be coloured so way easier to splice ;)
http://www.clubgti.com/showthread.php?219775
Thanks John. I didn't find coloured loom. The clock was already in the car, but i don't knew neither the pinout on the clock nor the fusebox connectors. But i found what i need in your docs:)
