Any idea on compatibility of Motometer and VDO
Hi, have the dreaded flashing oil light and constant buzzer fault on my 83 gti clocks- all MFA functions ok. All tests completed to sensors and wiring checked so bought a set of clocks off ebay, fault now gone and oil light on till started and off when running. Problem is these clocks are in a very poor state and not much else works. So this is where I stand now, got my golf clocks and a set of scirocco clocks stripped on the table but they are motometer and vdo. Does anybody know if they are compatible or if I could damage something if I try the L shaped pcb and rebuild my clocks. Otherwise it means taking my second set of clocks out and stripping another set. I know this is a common job from searching for fault cure so hoping somebody can advise me. Thanks Alan
