no spark gggrrrrrrrr
(In Topic #215635)
it just seems to be one thing after another with this restoration!!
i got no spark ive changed everything!! module, ignition coil leads, theres power going into all the above but just not producing a sparkfrom the coil?? its just one thing after another ive fixed the vaious fuel leaks i found once powering the fuel pump, again which i think ive done incorrectly as when i take the relay out its still works off the ignition?? i followed the fuel pump topic on the forum but not sure if i done it right!
im sure i will get there but all the help will be muchly appreciated ive enclosed some pic of what ive got and done pleeeeeeease help before i push it into a river
Electronic ignition or points….
Electronic, on the side of the dizzy there is a connector.
carefully separate the rubber boot off the plug.
with a DVOM 20V scale
There should be a positve, a negative and a white and green signal wire. Place your meter on the signal wire, and the other side to ground.
Key on Slightly rotate the dizzy, you should see the meter go from 0 to 11V and the fuel pump should run.
Back it off and re-do it.
That verifies your Hall Sender, so suspect the ICM or the coil.
points, then adjust them and replace the condenser
OH Timing set the timing statically..
Is ur coil earthed. Not sure if these are the same but Im restoring a mk2 escort and I had no spark. For the life of me could not understand why. Anyway I got so annoyed I just bolted it all in place and I had a spark. It seemed that for some reason the coil had to be earthed to inner wing by the cradle for it to work
And there is an earth cable from the coil bracket to the engine/head??
No that could be the problem, gonna try that when I get home! Hopefully that will do it, could the fuel pump relay have anything to do with? As I'm not sure I wired that in properly? I followed the link on the forum but if I unplug the relay it's still comes on when I turn the key?? But pump is defiantly working as that's how I discovered that the banjos were loose when I got sprayed with petrol
I found out I have a jh engine with a moody k-jet ecu for the emissions side of it would that have anything to do with the spark? I didn't think so because its all getting power ?? I will try and try again later!! Keep you posted
Thanks again for all the help
Well the fuel pump relay, usually is powered off the coil…. So you may have something amiss.
With no fuel pump relay installed and you turn the key, then there shouldn't be any fuel pump activity…
Grounds Grounds Grounds,
Can't pound on that enough…….
Battery to frame, frame to engine/tranny.
Head (valve cover) to bracket on coil.
Shoot, there shouldn't be any emissions crappage that will prevent spark.
I would start resistance or voltage drops between the engine and the battery, then the frame to battery, Should be basically the same as between battery posts, over a .5V difference then you have issues on your cables usually groundy ones.
Also measure the difference between the Coil Bracket and frame to the Positive Post (voltage)….
Grounded and still no spark ⚡️ and it has power not sure where to go from here
im going to try another coil see if i had a faulty one and then the icm but again these are all previously new so not really sure what its is as still have no spark, checked the ground and check i have power on icm and power on the coil, see what that brings
can somebody please just tell me the wiring configuration just so im on the right page please
i have 2 black wires
one green wire
and 1 black and red wire
thanks in advance
one green wire
thanks in advance
Is it the 8v 1.8 gti engine if so will take pics of mine
yes it is thanks for that
Coil
Red is on same twin block as the green.
Dizzy
Hope this helps
Dizzy
Hope this helps
Note the red/black and green are on the negative terminals of the coil
thanks for this i this, thats how i done it, i notice you have the 2 black wires connected together then attatched to the coil? i have both black wires connected? not sure it makes a difference, i also notice the chunky wire you haveattatched to the bracket where does that go for your ground?
thanks again
thanks again
Both my black wires go in. One in to each connection. that's just a bit of electrical tape holding them together. The earth strap goes on to a Bolt on the rear of the cylinder head just below rocker cover passenger side. Can't get pic as cany get phone into good enough position
Aslo give earth strap good rub down with wire wool or fine sand paper for good conection
thanks ill give it a go tomoz
Right guys changed the coil again and I got one spark so nearly fell over! But then nothing and haven't been able to get one since? Any ideas ??
I've done all the grounds
I now have changed the coil twice
I also changed the icm then got another spark
But then nothing ?
Does the icm need to be earthed?
Or is there anything wiring wise that could be blowing the icm up or the coil each time ?
Thanks again
But then nothing ?
Thanks again
Some one may correct me but I believe The icm is earthed from the plug straight to the battery
