No dipped headlights, plus other electrical gremlins, my troubleshoot thread
(In Topic #241395)
Thought someone might find this useful. My cab had these problems when it arrived:
Horn didn't work
Radio didn't work
Headlight washers didn't work
Dipped beam didn't work
Full beam didn't work
Full beam flash didnt work
Indicators and hazards didn't work.
Step 1: check the fuses
I checked and replaced a few fuses, and cleaned everything with contact cleaner. That fixed:
Radio
Hazards
Indicators
And the full beam flash can't back but only with lights on (see later heading)
Horn:
I took the cover off the wheel and the sponge turned to dust. Noticed the contacts weren't touching, so I bent them a bit and the horn worked, but came on a lot. So I made a new foam bit. Horn fixed. But I noticed it didn't work with ignition off. Hmmmmm.
Lights and washers.
I suspect it's an ignition switch, but take the wheel off and give contacts a good clean. Washers return but I'm not convinced it's not the switch. Lights still not working.
So I've ordered an ignition switch. It was a tenner, hopefully that'll fix it.
I *think* I would have fitted that first had I had my time again as I think it's intermittently not working, which is making me falsely think I've fixed things.
Sent from my FP4 using Tapatalk
Horn didn't work
Radio didn't work
Radio
Hazards
Indicators
Horn:
Lights and washers.
Chairman
Headlight washers only work with the lights on so will be linked to that if they're still not working.
I did not know that ref lights and washers. Seems odd. But you live and learn.
The main Ground for the Steering Column Switches
is a small Ground wire from the Steering Rack mount over to the steering rack gear box.
It attaches to one of the Bolts/screws on the steering racks gear box's
Chairman
I didn't either when I got mine. Being a man I hadn't read the owners handbook properly and set to cleaning everything, making sure the pipes were clear etc.
I only realised one night as I pulled into the garage and thought I'd clean the windscreen for some reason.
A strong spray came over the bonnet!!! 😳🤦♂️😆
So. New ignition switch, I now have headlights dipped and full beam WOO!
But no headlight flashers when lights off - so I think that must be stalk.
The flash stalk pulls a bit on the wiper stalk. Do I need both or one, if so which one? Might just buy both tbh
Actually had a second look.
At some point it's had an alarm. I wonder if the wiring to ignition live is a bit rubbish.
Time to find an auto electrician I think.
