Name that plug take 2!
(In Topic #197964)
2 point plug with red/white and black/white
Black/blue wire on its own just floating around
Thin brown with tiny spade on the end
Small bulb holder with white/lightblue and brown. This looks like an alarm tell, but no sign of an alarm anywhere on the car.
And i've just noticed looking at the picture that one of the plugs has an un connected point on the back, so possibly I have the plugs on wrong!
Have you got a better picture of the wiring spliced into the wiring by the switch to where it goes?
The radio is fitted in this area so the wiring does get attacked with scotch locks if they can't find the factory wiring.
What year is your car?
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
black/blue needs a spade on it and it pops to pin 15 of the hazard light switch
brown is an earth for one of the illumination bulbs as said, iirc its for the hazard switch again
bulb holder look around in the switches, ciggy lighter and heater panel looking for something without a bulb in. again, probably the hazard switch. if its only got 1 wire to it, the brown wire above is the other wire it needs
