MPH/KPH difference
(In Topic #223510)
Does anyone know if it is a different speedo for KPH, or just a different gear?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Depends on the gearbox. 020 gearboxes have 3 different speedo drive gears IIRC. The 084 or 085 only have one.
See my videos, Tom AFH
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I usually find that there is about a 30 mph difference from KPH .
over here if I do 95kph, I get runned over on the interstate as I am doing 60mph.
Your clock in in KPH?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Shows MPH but has the KPH on the inside.
Same as mine then. So it would be the clock that needs to be changed, Not just the gear on the cable?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I think the gear in the gearbox would be the same, as depending on what box you have you have different colors for the tranny, then you have different toothed gears in the speedo…to correct the speeds on then.
Ah, so I need a new speedo, or gear from an MPH one?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Differences in the speedo type.
90 MotoMeter gearing.
89 VDO gearing that has the red gear, and you can get variations in the toothed versions . the gears are pricey.
Wow, did you just happen to have both lying around? Thanks for that.
I guess I'll have to open mine…
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I had a 89, that I took apart years ago, then I have had a plethora of 90's that I have taken apart and repaired…I take photos…. lots of them….
For folks that need them, just like you.
The earlier ones were on a 2mp digital camera…. so they are fuzzy.
Wow you have a MotoMeter unit, with the speed sensor for the Sound control on a Aktive stereo as well as Cruise. See I can tell a lot about things with pictures.
Oh here is a gimmie, if you only have 2 wires on your speed control connect, you can put it in either way and it functions correctly.
Nice! Now all I need is an active stereo and cruise control
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Okay here is the donor. How do I make the transplant?
Is there an easy way to change the millage without connecting it to a drill and spinning it?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Yes it requires further disassembly as it get it out of the housing.
Carefully NOTICE THE WORD CAREFULLY move the needle over the stud to the right.
Using 2 Prys (pad the face plate) directly under the needle against the pin pry it up and off the pin, do not try to use the needle end you will break it. The needle pry is next to the shaft that holds it on and directly under the big black circle. Once the needle is free, then you can remove the face plate.
With the face plate off you can them use a pick, and move the keeper to the side of the number and roll it about to the correct mileage.
As we are being careful, you mean move it with this?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I got bored and wired up a bedside clock:
Anyways…
I can't seem to move the keepers (I assume you mean the white things above the numbers). I tried to slide them left or right, but they don't move enough.
Anyways…
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Eventually I slid out the metal bar holding the white things which allowed me to change it. Perhaps that's what you meant.
Going back to the board. I have tear which explains the lights not working, but there is also another break…
This seems to go to ground in one direction, and into something (is it the voltage regulator?).
Could this explain the MFA not working?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
