Mk1 Instrument cluster
(In Topic #208647)
Keep losing rev counter
Any ideas?
1988 mk1 Golf Clipper Black .
If you buy it at an electronics supply or on line from www.mouser.com they are about 75 cents.
If you order it from the dealer it is about 45 dollars.
Add a new ground to pin 2 (brown ) to your cluster as this will only help you, splice it in behind the connector (wire side) and use a sheet metal screw to the frame behind the "X" brace.
3m wire splice works good.
Carefully remove the shroud from the main connector, extreme caution to lift the mylar off the tongue, then add one piece of electrical tape on the pad side of the tongue of plastic reseat the mylar and the shroud.
The 10V stabilizer can effect all the above that you mention if it goes wonky the wrong way, also the ground pin. Now the addition of the tape to the tongue will tighten the connector pins to the mylar pad.
Back feed voltages or ground to it via the 10V stabilizer.
The Fixes I show up above aren't that hard to repair, fix, or redo. Easier than back feeding, and a lot easier than repairing the Water Temp gauge for flaky solder joints.
It could be as simple as the adding a piece of tape on the tongue of the connector.
But you asked what is the fix, and well all 3 are the fix, or back feeding the voltages when there is a bad mylar run.
Also worth a look at the ignition live feed for the cluster, its the smaller black wire coming out the back of the ignition switch
best to start with the simple checks then work your way up
The instruments mentioned above are sensitive to voltage fluctuations. A lot of the other stuff isn't.
There is a 10V stabiliser on the back of the clocks.
I had issues with my clocks I found intermittent problems went away when I tapped the clocks or top of the dash.
This showed poor connection to the clocks on the multiplug and blue Mylar film.
I cleaned the copper contacts and padded the tongue the foil fits over this gives a better contact.
Never had an issue since.
