Main beam round the wrong way
(In Topic #217253)
my main beams seemed to be round the wrong way when I pull the stork and the blue light comes on the dash this is normal lights them when I pull it again the blue light goes off and my full beams light up the road ??
Any ideas ??
Apparently it's a mot failure ? I don't mind it but would like to get it solved if possible
Thanks in advance
I do believe that if I pulled a Stork, it wouldn't turn blue, it would bite me.
If you turn on the switch, with the key in and in run, the headlights come on low beam.
If they don't come on check the fuses there are 4 of them for the high/low 2 per side
If the lows come on, then pulling the Stork (stalk) partially will turn the lows off (main beam) and the high portion will light along with the inner beams.
Pulling it to click will keep the center highs on as well as the highs outer.
On the lamps, there are 3 wires
Blue, white, and brown. or depending on your car
Typical headlamp wiring.
As you didn't mention your specific model, I can't be more accurate to your issue with wire or fuse numbers.
It's a mk1 caddy with cabby gti dash and loom,
Basically the whole function is round the wrong way when I go to put my full
Beams on the blue light on the dash comes on but my lights go to normal driving lights when I Turn the full beams off the light goes out on the dash and then full beams come on
Yes it's relayed all
Other lights are working as they should side lights etc etc
Thanks again
