Main Beam indicator light
(In Topic #217566)
Blue light not working
Add a new Ground to the cluster from the frame behind the X in the Cluster mount to Pin2 (brown) wire about 6" back.
LED's by nature are turned on or off by as little a .25- .5V difference, and the fact that yours are dim indicate to me that you have either an issue with the supply, that is 12vB+ from pin14 of the connection or Ground.
Improving your Cluster Connections and ground. | Volkswagen Owners Club Forum
Then again LED's do go bad. IIRC it is a white led, that has a blue cover over it.
