Loose plugs in engine bay
(In Topic #220048)
What colour are the wires and where do the wires go, it's really hard to see in the picture….
Are the others white/red and white/black or white/blue or green? as those would typically to me to be the upshift indicators wires from the dizzy and the transmission on the later Scirocco's.
however I can see you have late style 2 pin reverse switch, so even if you had the loom section it wouldnt plug in anyway.
you only need this loom if you have early type clocks with the big MPG needle up top with shift light, if it has later clocks then you dont need to worry
