Lights part no for 1991 cabby
(In Topic #221276)
So I've look over this document but can't figure out which I need http://www.cabby-info…/Files/HeadlightTypes.pdf
Is it a 5006 (5.25") conversion I need?
Like this https://www.amazon.co…tyle-Acutal/dp/B07F322727
Also the outer lights (marked red) are they 6024 (7")?
The inners over here where never a sealed bulb. They had a h3 or h4 bulb.
155941783C left yellow
155941783F left clear
155941784A right yellow
155941784C Right Clear
You can usually find them on VW Heritage as the Hella Conversions.
They are different for each side.
They take 1 each 171941605 rubber boot besides the Bulb.
How to relay your head lights 2 and 3 relay schematics.
Relaying your Head Lights | Volkswagen Owners Club Forum
How to safely remove your inner beams.
Cabriolet or Quad Grille Hi-Beam Removal | Volkswagen Owners Club Forum
I'm planning on doing the relay.
So this is my inner headlights, my thoughts that they look like sealed lights. Am I wrong?
If they are sealed is it a 5006 conversion kit I need?
And here's the outer lights which I though was "non sealed".
Can't get to the car today otherwise I would have taken a closer look.
Yes remove the wires, squeeze the two metal fingers and that will allow the binder to swing away, and you can remove the bulb, yes my bulbs are missing from my Spares.
If you relay them you will have greater brightness, and take a load of the head light switch. One of the best and Cheapest mods you can do to ANY car.
