Lambda sensor wiring.
(In Topic #209895)
Abf plug connector.
Required plug connection
Will I be able to cut the abf plug off and wire up the required plug? Presumably the one I need uses less wired that the 4 in the abf plug.
This is mainly to avoid the hassle/expense of fitting a new lambda sensor.
Cheers for any help.
Sent from my SM-G935F using Tapatalk
if its a 2 pin then id assume its not using the lambda heater, and just going to the signal wires. I would recommend you wire the heater it helps to get the lambda up to temp quicker, easy done just need an ignition live and earth.
worth checking if thats even for the lambda at all, the ecu may not need one
