Instrument lights weak
(In Topic #193938)
You can try and wiggle the dimmer up and down a few times as it may just be a dusty resistor and do they dim more when adjusting the dimmer?
Another option is see what bulbs you have fitted and if you have 1.2w ones fit the 2w ones in there place but you will need to remove the instruments to get to the bulbs.
Last edit: by mark1gls
Simon
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
They were designed that way!
Paul's suggestion of changing to 2w bulbs makes sense. I just need to get hold of such bulbs.
Did I not say that in my first post? The heater controls may not light up as the bulb is hidden inside the panel and can blow as any bulbs can, it is possible to change the bulb but it's fiddly to open up the panel. You may have the early style control panel which has a bulb on the outside.mark1gls said
My light did not work for about 3 years then it come back on for 2 years and now it's stopped working again! May look at it some time but more important things to do to the car first.
