Indicators Flashing Too Fast
(In Topic #218380)
1. Keep bulbs fitted in repeater wiring & tuck away behind wing
2. Solder repeater wiring into front indicators wiring
3. Anything else?
Last edit: by Cushti
There is a thread on the web to turn your side markers in to Side flashers. so that may key you in to how to undo that which would make them flash at the proper speed.
Daniel Stern Lighting Consultancy and Supply
Pull the bulbs and see for yourself
Current rides:
Fitted numerous ones to bikes over the years when changing indicators
Only thing I would say about them is dont leave indicators or hazards on as the resistors can get very hot
Current rides:
As a OBTW, some LED units have a resistor inbuilt in them they are usually the more expensive ones, and in the lighting section of my Autoparts store they sell "add on" resistor kits, and LED flasher relays. While I don't think the relays are prone to work in the VW's it might not hurt…..
The Relay itself is similar to a toaster, that it uses a bi-metallic spring and a heater to warm up so it can oscillate between cycles for a given value of resistance in the wiring and OEM bulb filaments. Since there isn't any real impedance (resistance measurement of filaments expressed in Ohms) on a LED that is why you get the quick flash similar to a regular Incandescent based regular bulb being bad.
Too many years of Electronics…..
As a Caveat, I too jumped at the chance to replace all my clock bulbs with Ho'made led's in the sockets, LED's weren't available at the stores yet and the issue that I had originally was that the LED's weren't either bright enough, or didn't have the pattern of a Incandescent Bulb. Now they are making Cree Lights and LEDS that Diffuse the light but the original issue that I had was that with in 3 weeks of each other all the "Super Bright" leds that I used burned out….. I re-engineered them to produce less light (changed the value of the resistor) they lasted longer but all went out about the same time, that is Console, Gauges and such that I gave up and replaced with newer Long Life old fashioned Bulbs, and that was 7 years or so ago….
Whilst I agree that placing them in your house, reduces your electric bill, mine dropped 50 dollars USD a month. they aren't subjected to the vibration, and such and tend to last a good while, I don't think I replaced a CFL but one time, and after I converted to CREE or LEDS, I haven't replaced a Bulb in YEARS…. my two cents on and off topic.
Either and resistor is needed or a simpler solution is one of these
https://www.ebay.co.uk/itm/CF14-3-Pin-Adjustable-LED-Flasher-Relay-Car-Turn-Signal-Indicator-Blinker-RASK-/153086507937?hash=item23a4aabba1
Ian
I ended up fitting the reverse trailer lamp types into the chassis leg ends & just have to swap the clear bulbs out for amber:
