Indicators fixed but now the headlamps have gone daft!
(In Topic #197402)
Still fighting with my wiring loom!
Right after fixing my indicators and having all of my lights working correctly from the original loom with no more bodged wiring I got quite excited and booked my MOT for 8:15 in the morning.
Following this I went inside to get my dash board and then fitted it to the car, running the loom and popping the switches in the correct holes.
But now when I turn the side lights on I get dipped beam and when I turn the dipped beam on I get high beam.
The high beam does nothing from the indicator stalk with or without the headlamps on.
Any ideas? Ive checked the correct placement of wires etc.
Last edit: by specs
with it coming straight to dip on 1st click, do you have a relay lighting loom fitted, and if so is it a later car with a dimdip resistor? if so, unplug it
